Kiven422 wrote:Hello recently the front right brake hose on my 94 Q45 started leaking (I wonder if someone punctured a hole on it) Anyways I already have ordered a replacement hose.
I have unscrewed the metal hard line that comes from inside the car to the beginning of the brake hose. The problem is how to I remove the hose from the first bracket. There is a metal bracket that seems like it could slide off but its locked in by the other bracket that holds the hose in place. I have not found a way to get around that.
The other bracket in the middle of the hose seems easy to take off, just can't get that first one off. I have asked in the Q45 forum but they are fairly off topic there and I'm not getting any real feedback so any help please?
What have you tried? It sounds like you've gotten frustrated which takes away all gumption-trust me, I've been there.
Also, I kept you on track with the spring clip idea but you tripped people up by driving a car with a leaking brake hose. Also, unless you're James Bond or have an angry ex the hose is leaking due to age and neglect.
Its held on with a spring clip which slides off in one of two directions. Worst case scenario, just destroy the old hose taking it off, you can always zip tie the new one if you can't save the spring clips.
