HachiRoku »
https://forums.nicoclub.com/hachiroku-u1165.html
Wed Jul 09, 2003 3:49 am
If upgrading, I like blank brembo rotors, I don't need cross-drilled/slotted rotors because I don't expect to be in heavy braking conditions (at least not yet). Blank rotors don't wear out your pads as quickly either, but they will fade quickly when you start braking heavily in short time intervals.
Chances are, your rotors might still be good, check for thickness and see if you can still use them. Look in a service guide or whatever will provide you with rotor thickness information.
I'm soon due for brake pad change and kinda slow at doing the research since I have enough brake life to prolly last me til December (unless I start abusing the brakes). Just gotta sift through some old posts and see what people have to say about some pads they've used and then I'll figure out what I wanna get based on whatever information I get.
