brake help
RagingPanda
Car: 78' 280Z
I have no brake pedal power at all and when I looked under the hood there was brake fluid leaking behind the brake master cylinder against the brake booster. It could be either the brake master cylinder or the brake booster. Can anyone help out?
ricebike
2002 Quest
2005 Altima
replace master cyl
navysnail
yep. the seal blows in the master, fluid leaks out the back. its a fairly straight forward job, but make sure you are able to bleed the entire brake system.
RagingPanda
Car: 78' 280Z
thanks for the inputs guys. Now I don't have to spend about $100 to replace a perfectly working brake booster.
ricebike
2002 Quest
2005 Altima
snail or other NICOnaut:
does he have to worry about the residual brake fluid that leaked into the booster? I know that stuff can peel paint/cause corrosion that way...
navysnail
it doesnt leak into the booster, it leaks down the front of the booster and drips on the frame rail in the engine bay. mine did the same thing, i got some clear paint, scraped away as much of the bubbled up paint as i could, and went over it with the clear stuff before moisture could ever affect the area.
popogto
autozone might sell a rebuild kit which has the push rod, seals, and spring. i know they have one for the clutch master cylinder
ricebike
2002 Quest
2005 Altima
i'd go 4 the whole thing than just the kit: carries a lifetime warranty if it ever blew again (which my raybestos clutch master cyl did)
