Brake Help!!!!!!!! Please Help..
singlecamhonduhkilla
Car: learning all i can about this car.. some street racing.. etc..
HEY EVERYONE I NEED SOME HELP.. ITS NISSAN RELATED BUT NOT 240SX.. SORRYBUT HELP ANYWAYS...KMY MOM TOTALLY KILLED HER BRAKES.. TO WHERE IT WAS METAL TO METAL.. AND SO I CHANGED HER BRAKE PADS FOR HER.. THE LEFT ONE WAS EASY AND NO PROBLEM.. AND THE RIGHT ONE WAS OK TO DO, BUT IT GOT SOO BAD THAT IT LEFT RIDGES ON THE ROTOR.. BUT I THOUGHT NO BIGGIE.. NEW BRAKE PADS WILL HELP.. BUT NOW THAT SHE DRIVES AROUND IN IT.. AND SO HAVE I.. IT BRAKES OK BUT IT STILL SQEAKS.. AND THERES HELLA BRAKE DUST ON HER RIMS NOW.. SO I WAS THINKING MAYBE THE ROTOR IS JUST WARPED EXTREMELY.. OR SOMETHING.. ANY SUGGESTIONS PLEASE HELP!!!BEFORE I GO BUY A NEW ROTOR OR SOMETHING.. LOLJOE:help
Phantom
Yeah when its metal to metal you probobly are going to have to replace the rotors too, you know just sometimes as a precaution. I think in your case it wont still be the pads because on the 200sx SE-R the pads settle in after install but here for you your rotor having a groove in it will need to be replaced.
yellow_jacket
Car: 95 240sx
Whenever you do brakes you need to resurface the rotor or drum somehow. If you do not you will end up with things like squeeks and squeels. You can try removing the pads and sanding down the rotors, cleaning them with brake cleaner, and reassembling.
If you do decide to change the rotor(which you should have done in the first place) then you will really need to replace the pads again since they will now have grooves in them and will never wear in properly.
WOW.. I NEVER KNEW ALL THAT.. LOLUMM BY ANY CHANCE DO U ALL KNOW HOW HARD IT IS OR WHAT ALL I NEED TO DO TO TAKE OFF THAT ROTOR.. IVE ONLY CHANGED PAD NEVER ROTORS.. AND I DONT HAVE A SANDER AVAILABLE SO ILL JUST CHANGE OUT THE ROTOR .. BUT HOW THE HELL DO U TAKE IT OFF?? ANY IDEAS? JOE
ANYONE ??JOE
Touchdown038
Car: Computers, cars, sports
Taking off the rotors is a piece of cake. (At least for the 240 it is, I'm not sure about whatever car you're talking about) There should be 2 17mm bolts holding the rotor, loosen those and the rotor should just slide off. For the back, though, the rotor might be stuck to the e-brake hub because of rust. In that case, you would have to thread bolts into the two holes next to the lug studs and pry it off.
Might wanna check on those pads too, to make sure the groove in the rotor didn't eat up the middle of the pad.
Queamore
Car: Cars.
Also onec you get them off take the to your local auto parts store and ask were you can get them cut. If they were warped the whole car would jerk everytime you would hit the brakes. It usually takes alot to mess the rotors up.
