ricebike wrote:i know that you'll haveta turn it every 90 degrees, so those tabs on the pad lines up w/ the piston... w/out looking at the old pads themselves, that'll be hard to rule out that mebbe it was just not aligned...
I did not notice this. When I put my new pads on, I will pay close attention to the tabs. This could be my problem, as the sound is only from one wheel. I talked to my uncle at the Nissan place today, and he said when I change the pads, loosen the parking brake cable 3-4 turns. He did not tell me where the adjustment is though.
ricebike wrote:those toyota hoses won't fit the 240sx's...
Dammit!!!!!!!!!!!!!!!!!!!!They are free for use. Are the end fittings different or not long enough?
