Need some help with brake questions. I'm going to run a pathfinder or d21 master cylinder on my S14 for clearance since the hard lines are on the opposite side from standard master cylinders. I'm running the equivalent of evo calipers up front and z32 in the rear. I previously had a z32 17/16 but didn't like the pedal feel. I believe the z32 1" master would be perfect. It is a BM50. Too bad the lines are on the wrong side. Here is the split point(SP) and reducing rate(RR) that are available.
D21 - SP 427 RR .2
D21 - SP 356 RR .2
Pathfinder - SP 569 RR .4
For comparison the z32 1" is SP 356 RR .4 and the first D21 master is the same as a S15 with z32 fronts and stock rears. I'm leaning towards the first option unless anyone has input.
