Johnsonizzle »
https://forums.nicoclub.com/johnsonizzle-u276171.html
Sun Jul 30, 2017 6:45 pm
Hello, and thanks for reading. This is my first post.
I recently had a front wheel bearing replaced and about 2 weeks later I developed a strange issue. As I was braking, going about 25mph or less, I felt a terrible grinding in the brake pedal; not a bad brake pad or bad rotor grinding. When I came to a complete stop, the ABS light, AWD light, etc all came on. As I drove it the rest of the way home, the grinding didn't reappear. The next day when I started the car, all the ABS lights were no longer on. Then, when I was braking going slow (under 25mph) the grinding happened again, and again all the lights came on. Again, once the lights were on, the grinding went away. This has happened about 7-8 times. The grinding only happens when a) braking at a low speed, and b)when no ABS lights are illuminated. This phenomenon is completely unreproducible when the ABS lights are illuminated. Any thoughts???
Thanks in advance for your responses.
