96pathfinder »
https://forums.nicoclub.com/96pathfinder-u2566.html
Wed Mar 01, 2006 2:31 pm
Hello all. I'm having problem with 92 Sentra E.
Just the other day, brake light came on when I was driving. Sure enough, brake fluid level was below minimum. At the same time, I realized brake was VERY soft and it went to floor. However, brake worked fine. Just pedal was very soft.
Upon my inspection, I found brake fluid leak at the rear drum (wheel cylinder) So I replaced both wheel cylinders. However, brake pedal is still soft!
I'll try and bleed the brake tomorrow but....Pedal is soft whenever engine is on and if I keep on pumping the pedal, it'll get harder. But if I leave it for few seconds and press the pedal again, it goes to floor again.
I always thought when pedal goes to floor, its a sign of bad master cylinder or booster. What's the sure way to find out either MC or booster is bad?
Any help is appreciated.Thanks!
