brake fuse?
NickD85
Car: 2001 Infiniti Qx4
I'm pretty sure that I blew a fuse tied to the electronics hooked to the brake pedal. I had a trailer hooked up, & didn't realize that one of the brake bulbs was broken, causing a short in the circuit. Anyway, now i can't shift out of park without manually overriding the shift lock switch, and my brake lights aren't working. Is there a fuse that covers these circuits? I'm going out to check it out now, but thought i'd throw this up just in case I can't find it.Thanks,-Nick
alexf20c
Car: '00 SE 4x4
um ya, there's a fuse. it's called Brake Light.
NickD85
yeah thanks,i found it, was just wondering if there was a separate circuit for the shift lock, but they were tied to the same fuse so no worries. Its in the fuse box behind that little compartment on the drivers side if anyone has it blow in the future.
