Brake fluid
walt1227
Car: 2011 Infiniti M56S
What type of brake fluid does the M56s take?
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
According to your owners manual, Maintenance and do-it-yourself SECTION: 8-15 (page 430), it uses DOT 3 fluid. You can overpay for the official Nissan stuff, or go to your favorite automotive discount supply store and by DOT 3 fluid from them.
Debonair
Rogue One wrote:You can overpay for the official Nissan stuff, or go to your favorite automotive discount supply store and by DOT 3 fluid from them.
Amen. :mike
Ilya
In theory you can use anything that isn't DOT5 (which is silicone based). All of the previous ones are glycol based.
I myself have Motul RBF600 DOT4 at the ready for when I do my brakes.
ArmedAviator
Car: 2012 Infiniti M37x
I use Valvoline or Pennzoil DOT 4 synthetic brake fluids. Higher boiling point. Slightly more likely to suck up moisture, but I flush the lines every two years so it's a non-concern to me.
PostalsQ
Motul RBF600 DOT 4, For me
JCesar
I'm using ATE TYP 200 DOT4. I used a lil over one Liter. Amazon sells them at $18.39 per Liter. After this one I will switch to Motul going back and foward
ibc
Car: Infiniti M56x
