Even with a 340F wet/550F dry one must assume something like 440F average after 6 months.A single 80 mph stop will raise the oem pads to 400-450F [in summmer 100F ambient][If you haven't used the brakes in 10 minutes at speed]...........therefore by 5-8 minutes AFTER the stop the heat has soaked thru the pads [insulators] to the backing plate onto the piston and into the brake fluid.
Highly likely that the brake fluid is at boiling point or very close........surely not ready and able to do it again soon.
Worst case is stopping quickly off Interstate and into rest area, quick trip to restroom and back accelerating out the on ramp......you may have less than optimum brakes for 5 minutes till the air flow cools things down. 20 minute stops are better!
There is always a time lag after braking before things return to normal temperature.
Obviously 550/600F capacity is a lot better than 400F but that means changing fluids every 6 months or less.
The oem pads are optimized to stop best at 300-400-450F but used fluid is not!
http://www.seinesystems.com/BrakeFade.h ... htmCastrol SRF is the wet KING at 518F but costs $70 per liter.
Is $70 dollars per year cheap to save a wreck probably!
http://www.racerpartswholesale.com/srf1.htm
