brake fluid??????
ttinfinitiM30
Car: infiniti M30
has anyone used anyother type of fluid for brakes instead of brake fluid. its a hydrolic system so would auto trans fluid work? its hydrolic fluid? im a aircraft mechanic and we use a hydrolic fluid for those brakes, that is simaler to atf.
y im asking is that i now have to paint the under side of my car because the ABS pump was leaking and when the master cylder was replaced the fluid got on the paint there too. cause.... brake fluid eats paint like its a starving ethiopian.
im looking to use anoter type of fluid but am wonderin if anyone else has gone through this b4.
Urabus GodofTraction
Car: 2002 Subaru WRX Wagon
2004 Suzuki SV650
1988 Toyota Land Cruiser
1994 Honda XR600R
DOT 5 is silicone based, but I'm pretty sure you've got to flush out every bit of the old DOT3/4 fluid. I think they have a nasty reaction to each other.
Really, it's all about compressibility and boiling points. To that end, DOT 5.1 rules.
Looneybomber
Car: 02 explorer sprt (grn)
10 G37S (white)
You know, I'm not sure. All I know is I use DOT 3 or 5 where aplicable.
nametakennow
Car: '06 MINI Cooper S
ATE Super Blue FTW!
I think your experience with fluids would probably serve better than the rest of us.
However, brake fluid is just hydraulic fluid, so I don't see why you couldn't use any other hydraulic fluid.
PoorManQ45
As long as the boiling point and the resistance to moisture is high enough then it'll work
TrunkMonkey
Car: 2000 Lincoln Navigator
ttinfinitiM30 wrote:has anyone used anyother type of fluid for brakes instead of brake fluid. its a hydrolic system so would auto trans fluid work? its hydrolic fluid? im a aircraft mechanic and we use a hydrolic fluid for those brakes, that is simaler to atf.
automatic transmission fluid will trash all the seals in your car's brake system.
-demetrius
ttinfinitiM30
Car: infiniti M30
thanx...guys
monkey, u had the answer i was looking for. i wasnt sure bout the seals in the system. i know thats the prob with using the wrong type of fluid in a system, but i was hoping to find somthing that would work without replacing the seals.
now silicone based sounds to be rather friendly. dose anyone know if dot 5 is corrosive to paints?? cause if not then ill be going after that when i do my brakes.
nismofly
Car: 89 Nissan 240SX Hatch
racing fluids are actually normally a really high end 3 or 4...stuff like ate super blue and motul rbf600 are where its at
im not sure if 5 hurts paint or not
Mr1der
I almost wish Fred was around for this...
Dattebayo
5 will hurt paint just like the others.
But why would you have to worry about the paint again as long as you keep up checks on the car and make sure its operating well?
You could use a different base paint, I guess.
ttinfinitiM30
Car: infiniti M30
2BN_S13 wrote:But why would you have to worry about the paint again as long as you keep up checks on the car and make sure its operating well?
paranoia
i really dont have anyreason to be concerned. but its just the fact that in the first place... all motorcompanies use a fluid that is corrosive to paint. and a good paint job is the leading product to prevent rust. i find it kinda rediculus that its in there in the first place when there are other types of fluid that would still have the same working power, but dont deteriorate other parts of the car after they hit itits no question that problems happen..ie master cyldr goes bad, abs pump leaks, or even just a rotten line somewhere. after a while all that stuff can happen. it would prevent the rusting of the car if that chemical wasint in there in the first place, and somtihing else was..
the real fact, is that im jus pissed cause i have to paint some areas of my car because of this happening
thanx all for the help
Bronze MFP
Car: 1987 Nissan 300ZX w/digital dash radness
castrol srf, nuff said
AmoebAssassin
Car: 1991 Base fastback 5spd, black
I always use ATE Super Blue in my car. We use Motul RBF600 in our formula cars.
ATE is cheaper than RBF600, but has a slightly lower boiling point. The ATE fluid is also less available than RBF600.
