Knk wrote: I look at where the brake booster line connect to the brake master cylinder and it was dry.
<huh?> booster line shouldn't be connected to the brake master cylinder @ all! that is a vaccuum line & shouldn't have any brake fluid in it.
Quote »...But from where the brake resevoir thing connect to the master cylinder, its was wet.[/quote]
U may have found 1 of the leaks. brake resevoir o-ring/seal. I doubt the aftermarket parts stores will sell this item; they'll probably recommend getting a new/rebuilt cylinder instead.
Quote »... Then I followed a brake line down to the driver side and it completely wet down there with brake fluid and it was destroying the paint. [/quote]u will have to pull the wheels off & check if it was just a trickle effect from the leaking of the resevoir down or is it leaking fluid @ the brake caliper/brake hose itself.
Quote »My brake pedal feels mushy when the brake fluid was empty and when its filled up, it brakes normally. [/quote]that's never a good thing; get that thing fixed ASAP b4 u rearend some1!~~~
