brake fluid loss-quick question
240DRFT
my 240 has been just sitting now and my brake fluid has gone down a lot. it was on min i filled it up to max then somehow its back down pass min. can it just evaporate from sitting there or is there a leak?
The Mic
Car: 3Z Wmb
No, it does not evaporate, you have a leak.
When it comes to leaks, do the common sense stuff first. For example, monitor the level and activity of the reservoir. detecting where the leak is coming from is another ballgame, so you could either plug it yourself or have a mechanic do it for you.
kane2g
Car: 92 240sx 95 240sx
my bet is on the calipers
eddiec
Car: 91 S13
get outside and check all the lines front to back side to side blah blah. follow from the brake MC all the way to the calipers. if no leak is evident then remove the wheels and check the calipers for wetness. i had to diagnose a leaky brake system once and it was leaking around the caliper piston seal. never would have seen it unless the brake pads were removed.
good luck
Slyce
Car: 89 240
My master cylinder was losing fluid too. It was easy to diagnose though because of the puddle of brake fluid at the rear right tire. I just replaced all the caliper seals and that fixed it.
navysnail
most of the time, it will be leaking from a seal, it is not very common to have a leak in a line or somthing, so you should check the easy things first (master cylinder), then go from there to check the wheel cylinders, and if you still dont find anything, then is the time to follow all your hardlines back and check those
slow s13
Car: cars, photo, music
look at you rims from the backside if your leaking this bad and its from the caliper seals it makes a big mess on the rim and tire
