r3v_v3ng3 »
https://forums.nicoclub.com/r3v-v3ng3-u58043.html
Mon May 19, 2008 9:44 pm
instead of guessing the problem, you should start by following the brake lines/hose/components inside and outside the car and see if you see any leaks.
find out where its going because if you don't fix it, its dangerous and it will eat your paint. also when you fix the problem, make sure you bled the brake system
