Brake Fluid Flush???
cousteau77
I'm replacing my old worn-out stock lines with stainless steel. How much brake fluid does a first-gen Q hold?
Thanks!
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Generally i buy a big bottle (Quart) and a little bottle (pint).. I generally go through most of the quart and have the little one handy for extra...
Q451990
Ditto on Wes' suggestion... I usually screw up and buy two big bottles, only needing a little of the second bottle. Then I end up tossing it... brake fluid isn't something that you want to open and then store. It absorbs moisture out of the air.
Heath
Jeff Williams
Car: 1994 Infiniti Q45t
2000 Infiniti I30t
2004 Infiniti M45
71, 72, 73, 82 & 2000 Corvettes
Just keep flushing until all the new fluid is gone. It won't do you any good in the bottle on the shelf.
Wes' suggestion is great. Keep a tiny unopened bottle around for top offs, if necessary. Most of the time just replacing the pads will get the level back to normal. There is really no evaporation of the fluid. It does absorb moisture, rather than evaporate.
