gumby74 »
https://forums.nicoclub.com/gumby74-u53716.html
Mon Jun 23, 2008 12:02 pm
I use the Valvoline SynPower brake fluid for both the clutch and brakes.However, the fluid should not have magically dissappeared. Chances are better than good that, unless replaced already, the slave cylinder went out. Considering the cost is roughly $40 with fresh fluid, I would suggest replacing both the m/c and the slave. And at some point invest in the long steel braided line that runs from the m/c to the slave. The cleanest, best way to delete the dampener box and greatly improves the pedal feel.
