C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Mon Feb 08, 2010 11:30 pm
Did it feel like teh ABS kicked in? That tends to make the brake pedal feel spongy. There is a specific problem addressed in a TSB. I don't have time to dig it up at the moment, but search either here or in the trucks section regarding the Titan. If this is the problem you are experiencing, and it happens again before its resolved, the brakes will still work, it just ends up feeling light and there will be a lot of vibration as the ABS is kicking in. It will be a little wierd trying to modulate the pedal, but its not impossible to do.
Most people tend to back off the pedal as under light braking, it feels like nothing is happening or that the pedal is sinking. Hopefully that is it. If you feel it happen again, and if safe to do so, take a quick peek at your dash. If the ABS or VDC light comes on, that's likely the issue. Outside of a brake fluid leak there really isn't a reason the brakes would stop working altogether. Even a brake booster failure would just require more pedal effort.
If this happens, I just turn the car off and turn it back on when it is safe to do so. Do take it to the Dealer and have them address this. Its supposed to be fixed with a simple reprogramming of the ABS unit. I had it done and while it happend a couple of times after I got my truck back, it hasn't happened in a while now.
