fxjackso wrote:Since your car is new, it has OEM pads. I wouldn't characterize the pads Nissan uses as "cheap." Any pad that produces less dust will produce less stopping power. Does it seem realistic that NAPA would outguess the facory's engineering staff on the pads for their new model?
NAPA lifetime pads are the most dust free pads I've ever used. Unfortunately, they're also by far the worst pads I've ever used. Very low coefficient of friction, and they would fade with only moderately hard street driving under conditions I've never faded any other pad.
Quote »There's a liquid cleaner called Simple Green. Use it full strength on cold wheels. No damage to paint, and gentle on the environment! Clean often, and you stay ahead of the problem. [/quote]Be careful using simple green full strength. I ruined the "crinkle" black finish on the valve cover on a car I used to own. I use a 10-20% solution, and it cleans brake dust just fine on my cars.
