szh »
https://forums.nicoclub.com/szh-u149.html
Wed Jul 02, 2003 2:44 pm
I'd still strongly advise against changing to non-OEM pads. The pad formulation that Infiniti uses has been optimized for their rotor, car weight, heat performance, etc. Generics cannot optimize in that manner for all cars - you might end up with insufficient braking capability or damaged rotors (can you say "warp"?). In a worse case scenario, if the heat is not properly dissipated by the rotors and overheats the hub, you can also damage wheel bearings. In other words, it may seem like a cheap fix now, but the potential for long term increased costs are higher. I emphasize the word "potential" - I am not guaranteeing that you will have problems! The point is: why take a risk?
Do a search for threads on brake pads over in the "Infiniti General" forum. You will see a lot of discussion on brake pads over the various model years. Most people end up sticking with the OEM pads for best results - not "all", but "most" - even the experts (see posts on brake pads by Q45Tech).
On my Q45, I use cross-drilled, slotted Bradi rotors with OEM pads and the results are excellent.
So, I'd say live with brake dust - just water rinse the wheels off regularly (after an initial waxing). It is performance that is far more important, not looks.
Z
