adidas2go »
https://forums.nicoclub.com/adidas2go-u78832.html
Sun Aug 24, 2008 9:24 am
Well, first of, you don't have brake drums, you have brake discs. 4 wheel brake discs. If your referring to the heavily rusted part, that's the hub. Yes, you can paint that. You will have to tape off the disc face itself though, to prevent any paint from getting on the friction surface.
Make sure you sand paper down the hub to the bare metal first, then paint it with some sort of primer based paint. That way, it will stick to the metal well
