Brake creeks and pops.
smokey240sx
Whenever I step on my brakes it creeks and pops. It still make the sound even when the car is off.
Modified by smokey240sx at 5:46 PM 6/19/2006
whiterps13
Car: white LE hatch
Sweet. Do you have a question or something?
cdlong
Car: '95 240sx
where is it coming from? the wheel area, the master cylinder, or the pedal?
spider_slayer
Car: S14 240SX
S13 240SX
whiterps13 wrote:Sweet. Do you have a question or something?
it could quite possiably be worn out bushings.
Eddie
Car: 1995 240sx se
I am assuming you have z32 brakes because my z32 do that all the time. I can be stopped and press the brake peddle and still hear a creeking sound. I know other people on this forum have had similar issues, but I have not run across any old posts that have solutions to that problem. I order all new hardware like that pins clips etc. I will install them next week sometime. I will see if that fixes that annoying brake noises.
skydragoness
Car: 03' 350z Touring 6spd
92' 240sx 60k survivor :)
Eddie wrote:I am assuming you have z32 brakes because my z32 do that all the time. I can be stopped and press the brake peddle and still hear a creeking sound. I know other people on this forum have had similar issues, but I have not run across any old posts that have solutions to that problem. I order all new hardware like that pins clips etc. I will install them next week sometime. I will see if that fixes that annoying brake noises.
I have the same noises too with my Z32 front brakes. I have all new hardware and everything is installed properly. I don't know why they are so 'vocal' though. They make a sound when they grab when they are cold (like a short groan), which then goes away when the brakes warm up.
