brake crazyness
1962-1965 Datsun L320 and NL320 forums - The truck that started it all in the US. All 320-specific topics and discussion can be found here.
22350
Car: 1964 320 Datsun truck
I have been down the rabbit hole with my brakes.
Everying appears to be working normally , except one thing. When I park the truck overnight, the rear brakes bind in the morning, until I drive the car for 20 minutes.
They are adjusted by going all the way tight and backing off 12 clicks. They are just barely touching when adjustment is finished and the car drives normally. The next morning the rear brakes are sticking. This problem only started after replacing the adjuster retaining clips. Clips are well lubricated.
The front brakes are adjusted the same way, but don't bind the next morning.
Things fixed:
too tight parking brake cable
replaced adjuster clips
wheel cyclinders
master cyclinder rebuild and check valve issue
brake peddle preload.
All hoses tubes springs shoes and new drums re-turned.
22350
Okay,
This morning I checked the rears, after the adjustment / drive last night.  The rear right was too tight.  The rear left was less tight.
When I drive, they get better, but still seem to be slightly energizing.
Should the leading shoe be shorter?  Is there a leading and trailing shoe for the rears?  They appear to be identical.
22350
Should the leading shoe, in the rear drum, be shorter as shown in the manual?
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
I think every drum e-brake I've ever seen had a shorter leading shoe. Is it possible you put two shorts on one side and two longs on the other?
22350
VStar650CL wrote:
Mon May 01, 2023 4:26 pm
everyone is telling me the rears are the same length
Return to “Datsun 320”
