dlhS13 wrote:Hey Nismo is there a real difference in brake feel and do they work good. Also did you make them or was it a shop. Ya what you have is what I was going for. They look really good. Saw a Indy car and they are inclosed just like yours without the hose. If it works for them it has to work. Any pics of the inlet on the bumper.
That's just some pic I found on Google to show you how most people do it.
The second pic is the stock M3 duct.
There is appreciable gains to be had with ducting on the stock diameter rotors and good pads. You still can't drive deep into the corner after corner but you'll have better bite. In the end the stock rotors are just too small for the car.
For a track setup on street tires I'd run Hawk HP+'s with ducting. They are noisy when they are cold but have enough bite when hot. Run some ATE Super Blue fluid or something comparable (there are a bunch out there). Theres better setups but this is cost effective if you absolutely don't want the Z32 setup.
Sub the HP+'s with Hawk Blues if you run R-compound or slicks.
When you are driving on the street I'd block off the ducts in the "winter".
