brake conversion help
POOPmouth
Car: The Devils pimp ride
ok- so this is what i have-car- 91 s13 coupe
-- have the 5 lug stuff but i just want to use the Calipers and rotors only-now my ? is
-- when putting on the z32 calipers- am i going to need the dust sheild to use them or can i just use the stock s13 dust sheild- and cut to fit-
as for ebrake- I would have to do anything to keep the stock e-brake- [email protected] more infoi know iv seen it covered before but i cant find it in ( search )let meknow- thanksfeel free to email me with any info regarding thisthanks
boriquaS13
Car: 92 240sx
Cut to fit or remove the backing plate all together bro. Don't forget about your brake hoses for the conversion also!
gumby74
If you do cut to fit, remember to round out those edges!!! As for the conversion lines, I used Agency Power lines BUT the rubber lining that holds the fitting to the struts slipped out while bleeding brakes. Ended up making a sleeve out of copper tubing I had laying around. Brake line still slides around, but no binding or sawing, all good.
