My 2012 Infiniti M35h experiences sudden jerks when braking during engine changes (combustion - electric). It's quite confusing and hard to explain.
When going downhill, it's most noticeable. I brake to slow down and brake gently, and suddenly it releases and brakes very hard, or releases then brakes, then releases and brakes again. The transition is rather abrupt, it's really unpleasant.
I don't have a fault in the OBD.
I'm going to start by bleeding the brakes and taking a look at the condition of the discs.
I thought I read that the ABS sensors can do this, even if they didn't show up on the diagnostic scan.
Same goes for the dual-contact brake sensor.
Thank you in advance.
