Brake clunking?
APCdude
An initial aside- the search button is proving to be useless as of late. I know this subject has been brought up before, but search will not find it.
About 4 months ago I replaced my front brake rotors, machined my rear ones, and put on all new pads. However, over the past few days, when I brake just slightly harder than normal to a complete stop (say, at a stop sign), one of the brakes on the driver side seems to slip and makes a clunking sound.
Does anybody know anything about this?
da40
Car: 1995 SE 240sx
did you put the clips on the breaks back???,are they the correct brakes for your car?double check
APCdude
Yep- everything is correct and the clips and shims are there.
APCdude
bump
ricebike
2002 Quest
2005 Altima
i say, remove wheel & take it apart & recheck them; might as well check the ball joint & tie rod end while u r @ it...
180fan
Car: 89 fastback
the clunking sound is coming towards the back or front? Once you've isolated it, have a look at that wheel. One of the caliper pin bolts could have come off, could be worn suspension parts (struts, ball joint, bushings) or even just something as simple as shims.
