Brake click
ikaruga
After I changed out all my rotors, I hear this clicking noise coming from the front of my car almost everytime I apply the brake pedal. It's not the clunk sound you'd hear if your bushings were worn, it actually sounds like "CLICK." If I push it down very slowly, no sound will be made. Has anything like this happened to anyone before?
91nis240
yeh mine started to randomly make that noise about a month ago, but i jus checked them out to see if there was an obvious problem, but there wasnt and my breaking power is the same so i payed it no mind really.
C-Kwik
Check to see if anything is loose. I've seen this happen when a caliper bolt broke off and the caliper would hit the wheel everytime you hit the brakes.
