pretzelboy wrote:Was under the car today cleaning off my 94 active underside---as I was spraying hoses and stuff I began to wonder if it was safe for rubber and electrical.....
Brake cleaner, carb cleaner, WD-40 and friends all contain chlorinated hydrocarbons. Chlorinated hydrocarbons ruin most any non-flourinated plastic and rubber, which means most plastics that are in use. WD-40, for example, has wrecked a lot of good plastic car parts and home products.
Chlorinated Hydrocarbons generally in use are Methylene Chloride, Perclorethylene, and Trichlorethylene.
A plastic can be chemically resistant to hydrocarbons and still be attacked by chlorinated hydrocarbons. I try to stay away from using chloribated products unless I am sure I am not going to wreck any plastic parts. Some plastics can handle spray with carb cleaner if they are quickly wiped/rinsed off. Don't soak plastics in carb cleaner.
