Touchdown038 »
https://forums.nicoclub.com/touchdown038-u3917.html
Sat Jan 31, 2004 11:42 am
Your rear calipers should screw back in, if you just push it back in with a clamp you will break something. Get a brake tool, or a pair of needle nose pliers if you're cheap, and screw the thing back in. Remember to either crack the bleeder screw or take the top off the master cylinder when you do it.
