gniknave »
https://forums.nicoclub.com/gniknave-u19269.html
Sat Apr 01, 2006 3:49 pm
[I'm posting this with a bad migraine please forgive any spelling errors or lack of info]
I've been going on low front pads for a couple of months now, not because I chose to but because I've had to. Last Saturday I started getting grinding from my passenger side front brakes (bad grinding). It would grind even when I wasn't pressing the petal, but much worse when I did press it.
After that, I didn't drive the car, and haven't driven the car since. I finally got around to buying new pads and rotors today (I had drilled ones that were obviously warped because they'd been vibrating for a while). Was going to put them on and I noticed the first issue on the drivers side.
ISSUE #1: The pistons leak fluid when they're pressed in. Common sense tells me this shouldn't happen. This was the side that didn't grind at all. Both pads on this side were completely even. However I didn't notice if maybe the piston had been 'seeping' before hand or not, but now it's just all out leaking when pressed. I also noticed the piston was quite easy to press, but I wasn't sure if it was supposed to be this way or not.
When I put it all back together and put the wheel back on, the wheel was able to spin 100% freely. [damn this Excedrin Migraine works!] I do know it didn't spin freely before hand, there was slight 'seemingly normal' restriction.
I definitely need a new caliper on the drivers side, is that correct?
ISSUE #2 I went on and replaced the passenger side pads and rotor. Now, this side went very smooth. Took me literally 5 minutes to get the caliper off, slap on the new rotor, torque it, put on the pads... you get the point....
However I did notice the pads wore unevenly. The pad that was grinding was the inner piston side pad - and it was metal on metal. There was 1.8mm remaining on the outer pad. Now, when I was working on Honda's, this usually meant a new caliper is needed. On this side, the piston did NOT leak when pressed, but it was quite stiff (but did press well with the C-Clamp).
Question(s)
1. Should the caliper piston be easy to press by hand (with little effort), or should it be very stiff and need to be pressed by the C-Clamp only?
2. On a Q45, does uneven pad wear mean caliper replacement?
Brake bleeding
I have searched for threads on this, but maybe whoever created a thread on this topic used a title that isn't so easy to find....
I am wondering what the exact procedure is to do this. I have read the FSM, but it doesn't explain this for the complete brake dummy (well, not complete, but almost). I'm hoping someone can be kind and post the procedure for me or link me to a thread where this is explained in detail.
Thanks in advance!
-Evan #2
