brake brackets for y33
Qproject
anyone know what size our brake bracket holes are ?
Modified by Qproject at 6:15 PM 2/24/2007
hannibal
Car: Red Line to Glenmont
Assuming theyre the same as most other Nissans of the period, they should be 12mm. These are the bolts that hold the bracket to the mount on the upright/knuckle.
Now that I type this, I'm not sure if this the size of the bolt head or the diameter of the hole...
EDIT: Pretty sure 12mm is the hole. The bolt head on a 240 is 19mm. I know the Z32, G50, and J30 calipers bolt onto the 240, so I'm assuming they all have the same size hole/bolt.
Modified by IWannaS15 at 5:57 PM 2/25/2007
Modified by IWannaS15 at 5:58 PM 2/25/2007
TXCumtrensh
Car: None
On mine, the front caliper cradle is mounted on with 22mm (7/8th) bolts, the caliper slide pins were 17mm (i belive).. the rear caliper cradles are held on with 17mm bolts, and the caliper slide pins are 14mm
Qproject
are the brake brackets the holes that the caliper attaches on to ?
TXCumtrensh
Car: None
Yes, the brake bracket connects the caliper to the spindle
Qproject
did the 97-01 q45T (touring) come with bigger calipers ?
hannibal
According to the FSM, theres no difference between touring and non touring brakes (rotors or calipers).
