SimpleEnigma »
https://forums.nicoclub.com/simpleenigma-u14504.html
Sat Dec 04, 2004 7:25 am
I have a '92 SE Coupe w/ no ABS or HICAS, and recently my brake pedal has become exceedingly squishy. not so that it touches the floor panel, but that i have to push very hard on the brake in order to get the car to stop...seems like the car just doesnt want to stop. I called a brake shop and asked, they said it could be that the brake booster is going bad, maybe due to the fact that brake fluid is extremely caustic and has worn out the diaphragms and rubber parts inside the booster.
so now here are my questions...1.) is this diagnosis an accurate possible problem or is he just BSing me and 2.) if it is the brake booster going bad, will the 300zx brake booster be a direct fitment since i am going to do the 300zx caliper upgrade anyway?
Also, the car has a weird vibration in 2nd gear b/w 20 and 30mph, only when engaged, a transmission shop says possible bad universal joint in driveshaft or lack of lube in univ-joint. Ideas?
