avrfan »
https://forums.nicoclub.com/avrfan-u102802.html
Sat Aug 02, 2008 10:12 pm
probably your pedal effort will increase. But most important I think is when you run a turbo, the system comes under pressure instead of vacuum.. there is a check valve in the line running from manifold to the booster so it doesn't lose vacuum under boost. make sure thats still installed. no vacuum means no assist. Try to find a booster that perhaps is not as thick but larger diameter so you keep same overall volume of the canister. Then you shouldn't see much degradation or negative impact on your brake function.
best of luck,Dave
