Well this is how it goes, My car has a vacuum leak...
and the symptoms of it is ill be driving, and all of a sudden when i touch the gas, nothing happens, like my boost gauge goes from - to 0 but nothing happens, My rpms keep droping and in order to get the car to start going again I have to let the RPMS drop down to idle then put it back in gear and go.....
I decided that problem is a boost/vacuum leak
and I pinpointed the leak to the brake booster and clutch booster
now my car is weird, the clutch booster doesnt connect to the plenum where the recirc hoes goes, It is on a T- connection from the brake booster connectiong
So the brake booster is connected to the plenum where it belongs then theres a T that goes to the break booster and one to the clutch booster, I disconnected the clutch booster side and tested if the leak was still there, and it was. thats how I pinpointed it to the brake booster, along with the odd pedal pumping and idle dying and low vacuum on gauge.
Now if you care to find out more about what im going through, This came first
91-tt-boost-leak-or-maf-or-what-t566123.html
and then this second
91-tt-clutch-booster-vacuum-leak-t567551.html
and the post in which we are posting right now is the 3rd pinpoint
Oddly though someone also said it could be my TPS needing adjustment? - Refer to the first link for the more detailed info as to whats happening to me )
ANYWAYS!!!!~ so what you want me to do is basically disconnect the hose from my brake booster and see if the problem still applies?
