IvoryJ30t »
https://forums.nicoclub.com/ivoryj30t-u9485.html
Mon Feb 02, 2004 11:08 am
ok, heres the procedure.
if there are no leaks, and your sure about it, do this.-
run the motor for a few minutes, and pump the brake slowly three times.
right before you shut the motor off, push the brake pedal and hold it down. turn off the motor.
if the pedal sinks to the floor, the master cylinder is shot.
then hold the pedal down for a few seconds to see if it wants to rise against your foot. then pump its three times.
if the pedal rises against your foot, or you cant get one or two normal feeling pumps before the pedal gets hard from lack of vacuum, the booster is shot.
