2BN_S13 wrote:Is the car's idle only when braking, or have you tried while in motion letting the gas off and letting it go down to idle without using the brakes? If your idle is rough then it would be your throttle body needs a cleaning because the area around throttle plate is gunked up...
Nah, just when braking. I've done a full tune up (plugs/wires/cap/rotor/air filter/cleaned throttle body/cleaned MAF/fuel injector cleaner in the gas)and it idles like butter when I'm stationary. Its almost like it holds a vacuum for like 2minutes because the first couple times I brake its fine as well. Just after a few high speed stops its drops down. Thanks for getting the ball rolling though!
