Brake Bleeding procedure for a 350Z
Nissan 350z / Nissan 370z general community discussion forum
Exar-Kun
Car: 2005 350Z
I am about to install my stoptech stage 1 upgrade (lingo for pads/lines/fluid). I need to know the propper procedure for bleeding the brakes on my 350Z. I understand HOw to bleed brakes (and have done it at a previous job often), but do not know the order a 350Z is supposed to be done, or if there are any special considerations.
I had tried ddowloading a FSM..but it didn't work. Does anyone know the procedure, or ahve acess to a dowloadable FSM for a 350Z I can use?
I'll be writing up the entire procedure to post later.
THanks
jEzTeR
Car: '07 Infiniti FX35
'02 Nissan Altima SE 3.5
'93 Nissan 240SX Hatch
Good Question!
I'll see what I can find out for ya...
I can't wait to see pics and write up.
Exar-Kun
Car: 2005 350Z
I'll post it up shortly. Unfortunately I'm going to ahve to go from memory and some crappy pics.
-Chet
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
Just as a matter of procedure, don't you normally go from the caliper furthest from the master cylinder and work your way towards it?
tiger
Is there even a 350z FSM floating around anywhere?!?
Corradoslc7
Car: 2008 Nissan Xterra VQ40DE
Darius wrote:Just as a matter of procedure, don't you normally go from the caliper furthest from the master cylinder and work your way towards it?
Yes most cars are that way however some cars may have a different procedure. Like my Golf R32 which starts with the left front caliper, which is the closest to the master cylinder. I am sure Exar-Kun just wants to be positive he has the correct procedure before starting.
Return to “350z / 370z Discussion”
