Z32 brakes are cable driven for ebrake that run the ebrake shoes...they have no affect on the hydrolic system.moso wrote:pedal hight is determined by how fast the calipers fill, if your rear brakes are not adjusted correctly they will take forever to contact. cycle the parking brake to adjust. re-bleed.
Snackman508 wrote: i swapped some brake pads that i had with more life on as well.
Most of the time yes, but not always. I am going on the OP knowing how to bleed brakes and he said the master is good until he has the lines hooked up. If the rotors and shoes on the rear are glazed and not seating properly the slip between them feels like a mushy pedal. Also if the park brake cable is over adjusted the brakes won't feel right. I've had customer vehicles come to me before with mushy, low pedals, high solid pedals, and variations in between. They usually have one common factor, the owner installed new shoes/ pads their self and did not break the glaze or groves from the old pads/ shoes. Then when they install the new pads they never seat/ break in properly and then glaze the pads or else the pads glaze on the high spots and never touch the low spots. That's why you shouldn't just install pads without prep work on the rotors. So I was just giving an alternate possibility to his problem, but since you know everything about hydraulic brakes I will humbly bow down and worship the very ground you walk on compactfean. Also I don't believe the Z32 brakes can be installed backwards because of the mounting position on the bracket.compactfean wrote:low mushy pedal Is a fluid related problem.
So the Z32 brakes can be installed on the incorrect side?SilviablhS14 wrote:I had the same problem once...turned out that I had the calipers on upside down. Make sure that the bleeders are on the top and not the bottom.
It certainly can. Neither of us know the exact condition of the pedal or the height of the pedal. When he stated originally that in order for them to grab he has to have the pedal all the way down. I took that as pushing as hard as he could before they locked up, that is how I perceived it. From that point of view the surfaces could be slipping on two glazed faces and require full pedal travel to cause them to lock up. We don't know what kind of pressure is required to push the pedal to the floor or the exact amount of travel. So you need to stop correcting me on someone else's problem, let the OP fill in the missing details since you don't know the circumstances. I understand how the Z32 brakes work, I was unsure of the mounting.compactfean wrote: 2 completely uneven surfaces are not going to make his pedal go all the way to the floor before grabbing. Bow to me or not....i asked you what you where talking about, you explained but still would not make any sense because we are talking about pedal hight, uneven surfaces,yes, can give you a "mushy" pedal until the 2 surfaces mate, even a pulsating pedal. Not a pedal to the floor.
