AcMav »
https://forums.nicoclub.com/acmav-u86256.html
Fri Apr 04, 2008 2:18 am
Rebleed them I'm pretty sure, the Bleeding process removes air in the lines, thats what the point is, If the car was never on, I'm pretty sure the ABS wouldnt be effected at all. It might be a pain to bleed completely again, I just bled my I30t and it took about an hour and a half to get all the air out of the lines. (I Installed new Brake Lines, lots of air in there).
If that doesn't work then I'd start looking at things like the ABS Controller, bleeding is always the cheapest option to fix brakes.
