thekawaii »
https://forums.nicoclub.com/thekawaii-u23206.html
Mon Sep 12, 2005 10:35 am
I got a pair of q45 calipers long time ago, i got those because of wheel clearance issue. (and price was less than 50 bucks for the pair)
Anyway, I've been doing lots of research, I learn that with Q45 brake calipers on S13, front brake force will set to 75% if rear brake is stock.
I know too much brake force at front wheel is not ideal (bad?), so what do you guys think i should do with rear brake?Anybody has experience with Q brake setup?
==================================================extra info: re-surfaced Stock Q45 rotors with stock Q45 pads. stock S13 master cylinder, stock S13 rubber hose.
oh. stock rear Q brake will not work because it uses drum brake for e-brake. i can't live without e-brake. i need it.
for both street and more auto-x
