hdfreak wrote:Not to be confused with Distance Control Assist (which sounds a little more like what you're describing used to happen). However, this setting is not turned on by default. I've never experienced IBA actually breaking.. just beeping. Maybe I'm not going fast enough at a slowing car. But with DCA, you'll feel the actual negative feedback on the gas pedal first, and then it will start hitting the breaks as you approach a car.
hdfreak & gofast24,
Thanks for the replies. I was out of the country and did not read the posts until my return. Yes, DCA was what I was thinking about. I thought it was turned on by default -- my memory failed me. I'm rereading about it in the quick reference guide and owner's manual.
I have a 2008 EX35.
