topless@vabeach »
https://forums.nicoclub.com/topless-vabeach-u1506.html
Tue Sep 02, 2003 8:53 pm
Take your foot and pull up on the break pedal, see if the light goes out. Sometimes the break switch sticks. I am not to sure what that has to do with you fast take off but that is where I would start.As for the battery light you can check the alt yourself with a voltmeter. Check the voltage with the car off- should be roughly 11-13VDC pending on the type of meter you use and how accurate it is. Then start the car and check the battery again. It should read between 13.5 and 15 volts. If you do not have a voltmeter take it to autozone. They test battery and alt for free.
Let us know what you find.
