Aven »
https://forums.nicoclub.com/aven-u152240.html
Sun May 16, 2010 4:55 pm
I have seats that will fit in the truck with some minor modifications to the brackets. The bolt holes in the front line up nicely, just sit up higher than intended. I can either find the means to flatten the tab and redrill it or shim the bracket at the bracket. Its sitting about 1/2" higher. The back brackets are my issue. I need to add a plate to be able to offset the bolt holes. The rear bolt hole on the new seat sits on the ridge just in front of the bolt hole in the floorboard and on the inside of the rails. Welding isn't an option for me unfortunately, so I will have to bolt it to the plate. I have some 1/4" aluminum on hand, but I'm not sure that it would be wise choice for the plate, even though I know I can fabricate what I need with the tools I have on hand.
