The A/T mode switch for the Maxima/Stanza/etc. is not a replacement for the kickdown switch as it serves exactly the opposite purpose. The kickdown switch is specifically for aggressive throttle situations. The A/T mode switch is for everything BUT aggressive throttle situations.
The Maxima has both. All the A/T mode switch does is set the RPM range in which the trans will shift during normal driving. Aggressive throttle will override that and force a downshift if "safe", just as with the Q.
To my knowledge, the "kickdown" function is universal to all modern automatic transmissions. It's not really a blend of luxury and sport, but rather a necessary function of an inferior system that leaves the driver with too little control (can you tell I hate automatic transmissions yet?).
ppastos wrote:Nissan unlike Infiniti wanted to save money or maybe another reason... But instead they used a switch which had the same effect as a kickdown switch but looked cooler.
Most certainly not the case.
The Maxima at that time was a spare-nothing flagship. It had it's own emblem (emblems if you count prior models) and was in a way it's own entity. Nissan was ABSOLUTELY NOT looking to cut costs in the car. I can say this with total certainty because of the fact that Nissan developed an ENTIRE NEW ENGINE (though derived from the VG) JUST for THREE YEARS in ONE TRIM LEVEL the Maxima. JUST for the Maxima SE, Nissan developed the VE so that they could fit a DOHC V6 under the hood. The engine had no other purpose. You don't do things like that if you're looking to cut costs or corners.
Aside from that, lack of kickdown function isn't exactly a cost-cutting measure, anyway.
