Firewind »
https://forums.nicoclub.com/firewind-u40995.html
Fri Jun 25, 2010 10:22 am
Wooooo lots of negativity on here regarding this idea.
Gcustoms, A lot of what people is saying is very true. You will spend less time, money, energy, and most likely have fewer problems dropping in a more common motor to the car, such as a KA, or SR.
Though, whats the fun in that, you want a challenge, something unique, or strange! I believe it's very possible to do this, part of the reason I believe this is because I also have considered doing this. Started out as a joke with my Subaru friends since I like the S13 body style so much, now I am researching the possibilities.
Things you're going to have to consider is making it a strait up racing car. ditch all your electronics, complete after market engine management IMO. That would be the easiest way, all new wiring in the car for the gauges, dump your AC and PS too. I mean if you're going to do it, do it right. I am not sure if the transmission spindle would fit in the Subaru crank, it may need some modification. Keep that in mind. Also you'll want to check on clearance issues for the turbo and down piping, as it would be up against the firewall in a 240SX if it mounts directly where the transmission sits now. You may even have to move the transmission forward to fit...
For me, the only way I am going to do this is if I can make it AWD. Yes, I am crazy, and I'm 27. :P
Good luck with what ever path you take.
