BOV Vacuum line
nab911
Car: 93 Nissan 240SX SE
Couldnt find this after searching but where should i run the bov vacuum line... i have no lines directly on my IC piping right now. I have my wastegate routed into the plenum so when the tb shuts it instantly shuts the wastegate to get boost back up. I dont know where to hook the bov line to and if it matters. Should it be on the piping or the plenum.
USDM_OneVia
Car: Racing
There is a nipple on the back of the intake manifold past the throttle body that I have T'd off for my BOV and boost gauge. Works fine for me.
Joe
Nismo1182
Car: Z06
There one nipple on the back of the intake manifold, one under the throttle body and one on the side of the TB.
I used the side nipple for my bov and boost gauge.The nipple under the TB for the wastegate and the nipple on the back for the fuel pressure regulator.
nab911
Well mine is exactly like that minus a t for the wategate. So ill get that done.
240 Trainee
Ok, I hooked my Blitz up like that, but it doesn't open, the compressor surges. Is there a way to adjust these? I didn't get a manual on it as it was used.
