Drakelee wrote:
I want to clean up all the useless crap, I love a nice clean engine bay... so I want to do as much deleting as I safetly can.
There are actually
3 hoses there. 1 is the recirculating tube like you mentioned, another is a tiny hose that connects from the bov to a vacuum source on the intake manifold plenum (needed if you wanna run a bov), and lastly (the one Im sure you were referring to) is for the iacv.
As far as I know, you need that hose connected to the cold pipe by the throttle body so the iacv can function and stabilize idle. The motors Ive seen with "re-done" cold pipes also retain that hose. I'm sure you could eliminate the iacv all together and control idle via throttle body, but I wouldn't bother unless you had a standalone system.
edit:
pictures of the redone cold pipes:
