BOV
EJL1985
Car: S13 240sx Red-top/ Toyota Solara
What is the second vacuum connection for, and what runs to it?
zach-Ka
Car: 1990 240sx (SR)
One on top is vacuum ( top right nipple in the TB.) and the bottom needs direct boost... i.e. anywhere on your intercooler piping. I have the same BOV sounds great.
EJL1985
thanks!
Justin35ll
Car: s13 coupe sr20det
Just leave the bottom one unhooked. All it does is cause a leak
zach-Ka
Really! Im gonna have to test that.
EJL1985
should I at least cap it? or is it better to leave it open?
Justin35ll
Well hook them both up first. Then when the car is running put your hand over the part that the air blows out of and see if your hand gets sucked in by the vacuum leak while at idle.That's what it did on mine at least. So I just unhooked it and left the top one connected. It won't make a difference if you cap it off or not
vr446
Car: S13
Have the same sweet BOV too, and mine is unhooked for over 4 yrs now...so far so good no probs
EJL1985
it doesn't seem to matter whether it's open or not, so I'm just leaving it open! Does anyone have low RPM whistling coming from the BOV?
Justin35ll wrote:Well hook them both up first. Then when the car is running put your hand over the part that the air blows out of and see if your hand gets sucked in by the vacuum leak while at idle.That's what it did on mine at least. So I just unhooked it and left the top one connected. It won't make a difference if you cap it off or not
Seishuku
Car: 1987 Nissan S12, 5-speed, SR20DE+T 50trim T3@15PSI, Megasquirt 1 029y4
The bottom port is for faster boost release, only connect it if you are recirculating.Top goes to a vacuum/boost source, the bottom goes to a boost only source (hot or cold pipe).
What happens, is when the throttle closes, the pressure in the charge piping spikes and puts that pressure to the lower port, while the vacuum is being drawn on the top port, opening the BOV quicker.The down side is that you will no longer have the boost holding the valve closed (equal pressure on both sides of the diaphragm), so you have to tighten it up a lot more or put in a larger spring. It can also hold it open while under vacuum only, so you must recirculate it or run with a blowthrough MAF or MAP setup.
EJL1985
Seishuku wrote:The bottom port is for faster boost release, only connect it if you are recirculating.Top goes to a vacuum/boost source, the bottom goes to a boost only source (hot or cold pipe).
I understand, so if the valve is a door, then it's opening up too easily on the low pressure side. Unless you counterbalance the pressure on the weak side, it will open with little force.
