BOV
8urstang
Car: 1989 240sx
i recently bought another 89 coupe with an sr already in it and it doesn't have a bov as part of the fmic.....can somebody tell me if it's needed and if it is what should i get an atmospheric or a recirculating one as well as if it should be on the hot pipe or the cold....i was gonna get one last night on ebay but due to the different ones available confusion set in and i don't wanna end up with something i can't use....i'm new to the whole forced induction setup so as much help as possible would be greatly appreciated!!!
Modified by 8urstang at 8:31 AM 2/16/2009
homeslicej2
Car: 1990 Nissan 240SX S13 SR'd hatch
umm.. I hope that SR wasn't running/driven without a BOV or bypass valve, otherwise bad joo-joo for your motor and turbo. You need a BOV, go with a good brand (HKS, Greddy, Synapse, etc.) Re-circ is always best with these motors bc of the MAF system and bc some BOV's are not designed for MAF cars without re-circulation. You can have stalling issues if they are not re-circed. Some, like the HKS SSQV will let you run open atoms. bc of it's design, but mine yielded slightly better throttle response after re-circing it. Hot or Cold pipe has different advantages/disadvantages. Search for those discussions. Most times, people place the BOV on the hotpipe. Searching will yield more info and help. GL.
8urstang
Car: 1989 240sx
what kind of bad joo-joo are we talking about...cuz yeah, it was running/driven without it, not for too terribly long cuz the car got wrecked after the sr was installed. just wanna know what i'm problems i'm gonna have to be looking for because of this guy being cheap
Seishuku
Car: 1987 Nissan S12, 5-speed, SR20DE+T 50trim T3@15PSI, Megasquirt 1 029y4
I doubt it did any damage to the turbo. It's not bad for the engine BTW, it's only a little hard on the turbo depending on how bad the turbine got stalled.
Things like broken compressor wheels, damaged turbine bearings, broken turbine shaft, stuff like that COULD happen if the turbo is stalled from not using a BOV, but it's not going to outright kill it if you drive with out a BOV for a few months.
And if you want to vent to atmosphere, change your MAF to a blow-through setup (search for it), you'll like it. And don't worry about people saying stuff about it screwing up the sensor, I've been running mine blow-through for 2 years now and never had an issue. I've only cleaned the MAFS once too.
redsx13
Car: 93 240sx 03 350z
8urstang wrote:i recently bought another 89 coupe with an sr already in it and it doesn't have a bov as part of the fmic.....can somebody tell me if it's needed and if it is what should i get an atmospheric or a recirculating one as well as if it should be on the hot pipe or the cold....i was gonna get one last night on ebay but due to the different ones available confusion set in and i don't wanna end up with something i can't use....i'm new to the whole forced induction setup so as much help as possible would be greatly appreciated!!!
Its not that bad, ive been running no bov for quite some time, (although its strictly a track car)
duffman1278
Car: 89 240sx Hatch, the wildcats!
You should be fine without it.
A Bov IS mostly an investment, its a security factor for your turbo. But I mean T25's are cheap. Which is what I'm assuming you have but I'm not sure.
But do some research since you said this is your first turbo'd car. There's alot of little things you need to read up on. I mean its nothing crazy new compared to a N/A vehicle.
homeslicej2
Blown turbo is the mostly the bad joo-joo I was referring to. To me, a blown turbo, no matter how cheap it is, sucks. Rebuilt T25, new gaskets, the time, etc. I'd rather pay for a good BOV.
